General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
Doing the first oil change on my bike. While the derby cover is off What should I inspect and what to look for?
2015 RK
The outer clutch basket cover and nuts pretty much take up all of that opening. The primary chain tensioner is self adjusting so not much to check there. You might get a finger on that chain for any loose tension but it should be normal/ slight movement. Best to look for anything large or foreign metal like in oil or on magnetic drain plug. Service manual may offer something else.
Unless something is obviously jacked up you can't see much. However, as long as the cover is off, take a sniff. A problem with the charging system could smell like burnt plastic.
