Question about cam chest cover
Hello everyone,first time posting and one quick question.I purchased a 06 street glide last August with 31000 miles on the clock.Do you have to remove the entire exhaust system or can you just remove the front pipe to get the cover off the cam chest.It has the stock exhaust.Thanks,Dave.
My 04 has a stock exhaust off a TC96 Night Train. All I needed to do was loosen the heat shield and roll it around.
Cover came fwd and off to inspect. If you pull cam plate and oilpump, might want to remove it.
Is so, replace that crush gasket and don't over tighten slip on exhaust band clamp. (If someone has not already done that) . Those two side bolts hold mufflers on, not the band to manifold pipes.
