Wind Splitter Windshield......What I Did Not Know.
First of all, I was told once I purchase a windshield it is mine. If something is wrong with it, too bad. If the color (smoke) is too light or dark or if it is not high enough or whatever, then tough. You bought it.
I would like to test it out first. But the HD I went to did not have a demo for my ’17 bagger.
I gambled and got a Wind Splitter. I was told it will push the air up and over my helmet.
I bought it, and it was absolutely no different than my prior windshield. In my experience, in my reality, the “up and over” did not happen.
I suspected because of the slight deviation in the windshield itself where it curves up just a little bit to get the nonexistent “up and over” aspect of the wind to go over your helmet, right with that curve is I thought there may be a slight visual blurring as you look through the curved part of the windshield.
Then I quickly thought, if it was a bad thing, they would not carry it and there would be many complaints. I am sure this is 100% personal but I definitely did not, not, not like that blurring.
My points being this.:
1) You can’t try it out. (There is no damage. But you can’t try it out.) Ok, I sort of understand it but no demo windshields for a newer bagger? ß The latter part got me.
2) There is NO “up and over”.
3) There is unpleasant blurring.
I posted this for 2 reasons. 1) To see what others think about the above matter and 2) to caution anyone else who is thinking about purchasing a Wind Splitter windshield.
BuzzCap7
BuzzCap7
Sounds to me that you purchased the wrong size. If you see blurring, you are looking through it, not over it. I had one too tall and the blurring is dangerous. Rule of thumb, as I read, is that the windshield should be as high as your upper lip\nose. How I check to see if wind is actually moving over me is to go down the road at 60 or so and with the left hand, start at face level and slowly extent your hand straight up. If the wind force against your hand changes, or doesn't would indicate how well wind is being pushed above you. I get the sudden wind blast when my hand is about a full length over the top of my helmet. Seats and windshields - there should be a way to try before you buy as costly as they are. Just my opinion.
This morning I am going to attach a cardboard (I know how to) to my present windshield at 12 inches. Do exactly the test you were talking about and now I will know for sure what the proper height should be.
Thank you my friend. I appreciate the post.
BuzzCap 7
Yes my friend. Thank you very much for that.
BuzzCap 7
BuzzCap 7
BuzzCap7 (12-09-2018)
Recurve? Is that like the "Windsplitter" of HD's?
I decided to go with Freedom Shields. https://freedomshields.net/They seem to be GREAT!! Thanks tho.
BCS ur FS (Freedom Shield) is thicker, did u have any issue getting it to fit inplace of the older thinner one? PLUS my friend, I have a windshield bag that goes in the slotted area to be tightened down as well.
Between the thicker shield and the windshield bag, will there be an issue opening the open section to slide all this stuff down into?
BuzzCap7
BuzzCap7
