Busted Exhaust Stud Removal
Ok, this has probably been covered a million and one times, but here goes again, as my search-fu sucks, and I'm honestly too pissed off to search more
Riding home today, I got a rattle and an exhaust leak out of the front head. Upper nut completely missing, and the lower stud is broken off just below flush with the head surface. Yeah, FML for sure. A quick look shows that a straight shot at the offending stud is obscured by the frame tube, so probably not able to remove this with the head in-situ.
I ask if this is indeed the case, as if I have to remove the head anyway, and cough up for new gaskets, I may as well put a reman set of heads on the bike instead of just replacing the damn studs. Before you all go off on me about needing new this, that and the other thing, budget is damn tight, but I still want it done right, and not rigged for future failure. I can swing a set of heads, but full blown top end (pistons, barrels, heads, cams, etc, etc, etc is out of the question)
Do any of you geniuses here have a shortcut, or does the head have to come off, no ifs ands or buts about it?
Bike is a 2000 Ultra Classic, engine is a bone stock TC 88 with 96500 miles on it.
Well, I can replace heads, and I can drill out studs, but this one I may not be able to do solo. I have a contact in at my Indy where I bought the bike. Hopefully they can do it without yanking the head. That adds a lot in expense and time for what on the surface is a simple repair. If they have the fixture to do it right, Ill just take it up to them. I just hate spending on labor that I could potentially do myself....
Location: Depends on who wants to know.........and why.
Received 1,902 Likes
My stud broke on the INSIDE part...HAD to take off the heads and jug.........also broke an EASY OUT in it...........no machine shop around here would touch it..........HAD to use a long drill bit to get around the fins..........little at a time with a small diamond bit on a dremel I got it out........real PIA!
Well, I heard back from my Indy, and the news honestly was as expected, the head has to come off or risk really screwing up the mount hole due to no clearance. Bike will be towed up there in the morning. They quoted 4 to 5 hrs turnaround on it, which given the scope seems reasonable. I could do it myself, but busted studs are a pain in the air, and with the head off, I have no good holding fixture for it. Leave this one to the pros
river john (05-29-2019)
