General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
Hey fellas, its my first time riding since the winter and i noticed my throttle sticking , while i was riding it was as if the throttle was stuck half open and would sit around 25-3000 rpm. I took the cover off and sprayed some cable lubricant in there but still nothing. Anyone have any advice? Thanks
Maybe the friction control on the throttle needs to be backed off.
Look at the throttle body where the cables are attached, twist the throttle and see if the operation of both cables look good at that end. If one looks like it's binding you could lube the cables.
seperate the controller with the buttons, (whatever its called) to look at the throttle grip. Mine did the same. I sprayed liquid wrench in and around the grip where the cables are connected, haven't had a sticky throttle sense.
