Road King Drive Belt
You are getting to a mileage that with all info and evidence, the belt is coming to the end of its use by date.... That being said,, if the belt is checked regularly and there is no major damage, there is a fair chance the belt has many more miles on it...
If the bike is a keeper ,, and for some reason in the next 10 or 20,000 miles you have to remove primary components, (compensator/clutch), my advice would be to throw a new belt on her .....
I replaced my friends at 100,000 it was about to fall off. However, he didn't baby it. A lot depends on how you treated it. Nonetheless, you are approaching a common mileage. Check the belt for cracks along the teeth or teeth that are lifted. You can do that easy enough.
Preventative maintenance IMHO is checking it regularly, both for condition and tension. When inspecting my own belt I found a sharp sliver of stone had penetrated it and dinged the rear pulley, so removed the stone and kept an eye on the wound. Your FSM explains what to look for. Eventually after around 4k miles the wound began to look as if it was spreading and I also had an annual vacation trip planned, so replaced it and the rear pulley.
