Fork Lock Stuck
Fork Lock Stuck
I have a 2010 Ultra Classic never used the fork lock so thought I should try it, so installed the key and put the switch in the lock position and turned the bars all the way to the left. It locked and I can not unlock it at all. is the a place to put a jumper to over ride the pock pin? Can the ignition switch faulty and if so can it be removed with the forks in the lock position.
Received 6,055 Likes
steelerdude1
04-14-2013 06:47 PM
