General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
2014 FLHXS with 26K mi given me service code UO184, any help would be appreciated. I'm calling local dealer in the morning but I'll sleep better knowing something.
the "U" codes deal with the can bus system, however, i do not find that particular code listed. in the auto world, that dtc is in ref to lost communication with the radio controls.
Had the same issue on a 19 streetglide special. Did you update the software? Mine showed up after an update. I cleared it and it has not come back at all
I've been riding mine just before this issue, It wont start and this radio code shows up. I guess there might be two issues? How do I clear the code myself?
thanks
bob
If i remember right you can hold down the trip button on the left grip housing. Turn the bike on while holding the button down DTC should show up where the code was displayed. You can now scroll through the codes. when you get to the code you want hold the trip button down and it should clear it. Its been awhile since I have done this. I'll double check at lunch and make sure I'm giving you the right info. I think you can google it as well.
thanks
bob
Just hold down the trip button until It says clear.
