Carb issu
The float level needle isn't sealing any longer. You can download details of your carb from the S&S website, which will show you details and exploded diagram. I suggest you buy a rebuild kit, strip clean and rebuild your carb. The kit comes with all the perishable parts, such as a new needle.
i figured a rebuild would be a good idea, i just bought the bike recently it is a rigid and has been put back to a right side shift so it is no longer stock i am wondering if i do the carb rebuild if my be the jet size may need to be changed as i am not sure what the carb came off of. Thanks for the advice this bike is going to need some work but that is part of the life.
