Wheel bearings
Wheel bearings
I am presently doing an end to end maintenance on a 2007 FLHTCUSE. I have the wheels off to remove and replace the bearings. I had to take the wheels to a friends shop so he could remove 1 bearing from each wheel. While he was wrestling with the removal he gave me a short education on the bearings. The manufacturer of the bearings normally puts only 10% of grease in the bearing
Why? Simple, that way they can sell more bearings. He showed me how to remove the seals from the bearing, yes there are 2 on each side, and with the seal off you can pack it with good water proof grease and reinstall the seals. Now you have a bearing with the correct amount of grease in it. To remove the seals use a small pick and pick it up from the inside of the seal, that's by the hole where the axel goes through. Same with the second seal.
HAPPY RIDING!
HAPPY RIDING!
HAPPY RIDING!
HAPPY RIDING!
Your 2000-2007 21mm wide bearings are of good quality and many last for over 100k miles, without any more effort on anyone's part
FWIW, If you didn't clean out the existing grease (although fresh & new), then you just contaminated the existing and current grease.
Bearings
No offense, but that's One Guy's Opinion (although many may hold that) that you just regurgitated
FWIW, If you don't clean out the old (new) grease, then you just contaminated the existing and current grease.
It doesn't take a lot of grease to provide lubrication. You don't 'fill' your primary case do you? Removing the bearing seal is not a good idea (it's a 'sealed' bearing after all). You probably sacrificed a some the integrity of that seal. The seal itself is what we benefit from. Bearings are damaged by over tightening and not using the right tools. Sounds like your pal did a poor job removing them and if you are installing them without a proper bearing tool you are probably doing additional damage. I never had to wrestle with a bearing and it takes literally seconds to remove and replace them.
if you research sealed bearings you will find that not full of grease is by design not cost cutting measures.think about it,pack a sealed bearing full of grease snap the seal back on and ride. things start to heat up and expand.with the bearing full there's no room for things to expand.the seal blows out and you have serious bearing failure.sealed bearing are not like the old tapered bearings.
