Derby cover replacement tips
I have a replacement derby cover on order and wanted to get any advice on unforeseen issue I may encounter when replacing. From what I have read I must keep the bike level to prevent fluid from spilling out. Since I don't have a bike lift I will improvise. Since the new cover doesn't accept the o-ring I have purchased a gasket. Do I need to use locktight on the bolts? Is a torque wrench a necessity?
Loctite I never do, but if you feel the need use BLUE - Torque (not sure the specific, google says 100 inch/lbs) good and snug you'll strip the threads if you tighten too much (there's no pressure in the primary. One of the easiest things you'll do.
Buy a jack and a manual and you won't have to say you don't have one.
NCBANDIT (01-08-2017)
You can certainly replace the cover while on the kick stand
No - next time you remove the screws you're asking for a stripped out head.., or two
Yes - in inch Lbs
Tighten / torque in a star pattern
Ghost
NCBANDIT (01-09-2017)
No - it's filled on the kick stand - which means the cover is removed
Yes - in inch Lbs
Most definitely this
Ghost
Yes - in inch Lbs
Ghost
This a harley forum - he has a harley
Asking for help swapping out a cover - newer bike - as anyone owning an older one would be wrenching on it already
So let's cover all the bases
OP
Stick a piece of 2X6 under the kickstand to upright the bike - then proceed accordingly
2X6 will provide a bigger footprint as opposed to a 2X4 - but either will work
Put / leave you bike in gear so it doesn't roll - also chock the wheels
Proceed accordingly as per above - oh and have some spare primary oil just in case
Now.... everyone happy..., happy..., happy
Ghost
