Front brake lever
Sounds like the piston in the master cylinder is sticking and not returning to its full out position. Most likely need to rebuild the master cylinder. A squirt of WD-40 or other lube may help temporarily, though.
The brake light switch is turned on (releasing the switch) when the lever is squeezed. The light is turned off (depressing the switch) when the lever is released.
BlackSmoke
02-22-2015 07:51 PM
