General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
Thought that would get your attention :-D
The red ignition light is stopping on after the engine starts. Now I know the sort of things it can be but is there anything easily checked before I send it to the garage please?
John
You probably have at least one trouble code that you should check. I don't know what year bike you have, but you can search on line for "Harley Trouble Codes" and find out how to check for them.
I didn't think they had red engine lights in 88. Post a picture, it might be your oil light. Which would indicate low oil or a faulty oil pressure sensing unit.
I think it may have had some mods R73. It has an alloy plate that the H/light is suspended from that contains 4 lights, Green/Neutral, this Red/Ignition, Amber/Indicators and Blue/Main beam. And as you can see from the picture it has a double tank with mounted speedo and ignition switch, neither of which are standard for this model.
