Gasoline
Gasoline
Of course I try to use straight gas 91 or higher octane, but sometimes you take what you can get. Recently my choice was 87 octane straight gas, or 91 octane with 10% ethanol. I went with the 91 ethanol blend, but am wondering whether the pure 87 would have been better. Anyone know?
Received 1,940 Likes
Oh,, if you use SeaFoam and start to experience vapor lock (revving) on hot startups, lay off the SeaFoam for a tankfull or two.
I am going to chime in here... I like to use the best fuel that is offered when I stop for a fillup.. so I would always lean toward the highest octane rating for my bike, not so for my car though... Ethanol is present in most fuels these days..E10, that 10% you spoke about, E15 & E85.. I stay away from the latter two like they are the plague... The biggest issue with any type of ethanol fuel is the rapid breakdown that occurs inside the fuel( never mid that they also like to attract moisture). If you are not going to leave the fuel set in your bike for long periods, it is not as much of an issue. If it is your last fillup before you put your bike away for a couple weeks..then I have a suggestion.. I have used a product called Star Tron for about the last 7-10 years..it is an amazing fuel treatment. It will prevent your fuel from breaking down, .. and.. it will actually rejuvenate fuel that has already begun to break down... Put a small bottle of it in your saddle bag, it is life blood for your bike!
Gommee
04-25-2013 04:37 PM
