extra part from throttle housing?
Old 10-03-2005 | 01:01 PM
yodal's Avatar
yodal
Default extra part from throttle housing?
I lubed my throttle cable yesterday, WOW what a difference. I screwed it all back together and it was sticking at half throttle. I opened the top cover again and this thing was sticking between the return cable and the housing. I have no idea what it is or where it goes. I looked in the manual and could not find a diagram that showed it. I've got the throttle together again with OUT this and all seems fine. Any ideas what it is, where it goes or if I need to worry about it?
Thanks
[IMG]local://upfiles/2625/2E3348A10F4A466BA247B2DFF5C30201.jpg[/IMG]
Old 10-05-2005 | 11:45 PM
rkc's Avatar
rkc
5th Gear
Default RE: extra part from throttle housing?
that little plastic piece is from the bottom of the housing, it sits ontop of the throttle tensioner screw.
you will notice a hole at the bottom of it ,just match the hole to the point of the screw and carefully reassemble the housing .
Old 10-06-2005 | 04:19 AM
mikeisglidn's Avatar
mikeisglidn
yep hes right!
Old 10-06-2005 | 10:45 PM
yodal's Avatar
yodal
Thank you very much guys.
Old 10-07-2005 | 08:27 PM
billvaughn's Avatar
billvaughn
A fine example of how good this site is...I know that would have bugged the heck out of me until I figured it out.....
Sorce
06-09-2019 11:37 AM
riverdawg1
10-14-2018 04:44 AM
harleyman15801
12-01-2013 11:08 AM
KDagostino
04-08-2013 09:44 PM
cmancini26
11-12-2011 10:57 PM
Quick Reply: extra part from throttle housing?
