Steering Stops
Old 06-13-2016 | 03:16 AM
Greenblood's Avatar
Greenblood
Default Steering Stops
Fitted Pro One slab triple trees to my 1984 Softail, only just realised that they don't stop the trees before they hit the tank!
What do I need to fit to stop them? Are there options?
Cheers
Steve
Old 06-13-2016 | 04:36 AM
Greenblood's Avatar
Greenblood
Here are some pics
Slabs in place, see where old trees hit frame
Pic between slabs
Old trees, top
What us this hole for?
Old 06-13-2016 | 07:28 AM
grbrown's Avatar
grbrown
Can't help you with that hole, but what is different about your old trees that stopped the forks hitting the tank? Are there stops on the bottom tree?
Greenblood (06-13-2016)
Old 06-13-2016 | 04:44 PM
Greenblood's Avatar
Greenblood
See Pic old trees top, these hit the aforementioned stops/frame.
I have dismantled the trees now, there appears to have been some stops of some sort fired to the bottom tree- see pic attached to this post.
Looking at mcs catalog, there is an internal fork stop with four holes needed in the bottom tree that may have been fitted. But that is for later style head where Bearings are fitted directly into the head. My early softie has the bearings in cups.
Any help appreciated. Ideally I want to reuse those holes, but if not use another solution.
Ta
Steve
VoiceofReason44
07-13-2017 07:59 AM
dave_simpson
03-12-2017 05:32 PM
99customst
01-18-2013 09:08 AM
10Seconds
EVO
05-02-2011 06:29 AM
bigscooter
01-20-2007 07:25 PM
