Dyno results
Dyno results
Here's my dyno run from my 15 Roadglide. Has a 2:1 Python, SE ventilator and woods tw-777 cams. Power drops off after 4,000rpm. Tuner told me it could be a few things causing that, short pipe, intake not letting enough air in, cam timing might be off a tooth, or oil pump o ring. What do you guys think?
I have to agree with OldEnuf. You need more compression and some head work to get the 777's to do what they do. I'm running the 777's with head work, 10.5 compression, Agitator intake, stock 50mm TB with a Dragula 1 and my tuner told me my engine wanted more fuel and air. My bike with this set up is making 104hp and 109tq and is fun to ride for a big ole geezer glide. I just don't think the cost of a heavy breather, 58mm TB and injectors is worth it vs the six or so more hp-tq I might gain.
