torque wrench extender questions
so I have a torque wrench that only goes to 150 ft pounds so will need to use an extension to install the SE compensator (bolt requires 175 ft lbs am reading)
Anyone else run into this? just looking for some tips to avoid pitfalls.
I am hoping to use an extension bar on the handle side of the torque wrench versus on the wratchet side (as most pictures show), does that matter?
requires a calculation to do....wondering how successful folks have been w/ this.
torque wrench extension calculation
I have checked out tools from Autozone before, but never a torque wrench. Was it 3/4 drive out of curiosity? or 1/2 drive? will give them a call, good tip, thanks.
Received 1,940 Likes
rubberfrog (05-06-2016)
Example:
100 ft/lbs with 1 foot handle = 50 ft/lbs with 2 foot handle = 25 ft/lbs with 4 foot handle etc.
More then wiling to stand corrected.
Edit: premise being, my torque wrench only goes up to 150, so, if I double the handle length (via an extender pipe on handle) and set the torque value to 87.5, it'll yield the 175 I want?
Not talking a vertical extension outward from the bolt, that won't increase the torque, talking about extending the handle on the wrench so a longer lever (guessing you knew what I meant but....)
Nope! The torque your wrench applies is dependent on the internal mechanism inside it. Nothing you do will change the torque applied at the point of twisting, where the square drive is. An extension to the handle will reduce the effort you have to apply, at the end of the handle, but the torque at the square is unchanged. Sorry, but you need a torque wrench with a higher torque range!
Have read conflicting everywhere online, from physics forums to elsewhere!
Thanks.
So, the 5-6 minute mark in this video is wrong?
https://www.youtube.com/watch?v=Dz1xl2U-hNM
Thanks.
Thanks.
You could experiment with lower values within the range of your wrench. Set the wrench torque per the formulae with the extension. Then tighten the nut until you reach the set torque, Then remove the extension, and set the wrench to the desired actual torque...then turn with the torque wrench, and see what happens. If it clicks..,you know the previously set torque was AT LEAST the desired setting...but could be more. So, now remove the nut, and torque it without the extension. Then redo the setting via the formulae and torque with the extension. If itbimmedistel clicks...you are good...
Recommendation: go rent, or borrow one.
