Breakout Clutch issue?
Old 05-01-2016 | 03:36 AM
Breakout86's Avatar
Breakout86
Stage II
Default Breakout Clutch issue?
Not sure if this has been bought up but Just went to roll my bike in gear but switched off and makes no difference wether i pull the clutch lever or not, the gears are engaging however when the bike is running there is no issue, can roll allday long with clutch in when in gear .. is this normal or is there something wrong? Havent noticed it untill now as it would usualy be in neautral.
Old 05-05-2016 | 07:14 AM
mdm's Avatar
mdm
Had it been sitting for a while? The clutch discs can stick together causing what you describe. This is why a cold bike may lurch a little when it is first put into gear. You might also check the clutch and cable adjustment. How long has the fluid been in the primary? Checked the level?
Old 05-05-2016 | 08:49 AM
Technician Dave's Avatar
Technician Dave
Stage IV
If I'm not mistaken, the Breakout is hydraulic clutch. I also believe there was a recall on the clutch master cylinder. I would check with your local dealer. Call the service department and give them your VIN.
Old 05-06-2016 | 09:23 PM
Dalt10's Avatar
Dalt10
CVO Breakouts have hydraulic not the regular Breakout.
DeplorableOne
07-31-2021 07:57 AM
trentchuck
09-11-2011 11:15 AM
bigredwing
09-01-2011 11:00 AM
mrthinkshesfunny
01-18-2010 02:11 AM
wolf1477
Ironhead
01-16-2007 04:23 AM
Quick Reply: Breakout Clutch issue?
