FLHR Cruise Control
Old 04-01-2016 | 08:28 PM
MizzerBill's Avatar
MizzerBill
Stage I
Default FLHR Cruise Control
Maybe someone can help. I have a 2013 FLHR...I wanted to put Cruise Control on it this year. Local dealer told me they dont have it anymore for my bike. It's wired for it and it was an option that year. Any suggestions on where I can get it ???
Old 04-01-2016 | 08:55 PM
Rustyg500's Avatar
Rustyg500
Harley Cruise control kit 77197-08 Fits 2008 and later FLHR. Consists of just handle bar switch housings, switches and wiring. You plug and play the left and right switch housing then the Dealer can activate the Cruise Control switch in the ECM using their Digitech.
If you can find the Kit switches or order the individual switches you should be good to go.
Check a 2008 parts manual for switch assemblies that incorporate the Cruise control switches.
Old 04-06-2016 | 06:02 PM
HotRod9mm's Avatar
HotRod9mm
Originally Posted by MizzerBill
........ Any suggestions on where I can get it ???
These guys show they have 4 in stock, but I would call to make sure.
Harley Cruise Control
The "Kit" is basically(as stated above) the left side control with the duel switches under the turn signal switch. If you are mechanical at all you could find a used switch housing and wire it yourself, that is what I did on my '12 FLHP. Not real difficult. I think my housing was off an '07
J McBri
04-24-2020 07:32 PM
Whiskyjock
07-13-2013 07:45 PM
KingCripps
07-31-2010 10:43 PM
lewain
01-04-2009 07:53 AM
dfa
04-02-2008 01:53 PM
Quick Reply: FLHR Cruise Control
