bike is sputtering in gear
Old 03-16-2016 | 02:34 PM
Chucklesgolf's Avatar
Chucklesgolf
4th Gear
Cool bike is sputtering in gear
Have an '06 lowrider, 96 ci. It starts, idles and revs fine, until I put it in gear. Once in gear, it spits, sputters and just really does not run well. Have replaced the plugs and exhaust gaskets. It does have a 3rd stage powercommander installed. Any suggestions as to what the problem may be, and an approximate cost to fix, as I am not, repeat NOT, mechanically inclined at all.
Forgot to mention, also used seafoam carb cleaner and fuel additive trying to make sure the jets and filters were clear. This was a sudden change in the way it ran, and had not showed any warning signs of mechanical problems before it happened.
Old 03-17-2016 | 10:19 AM
enodrano's Avatar
enodrano
When your engine is idling it requires very little fuel. As soon as you put it in gear, the engine gets stressed and requires more fuel to stay idling. Sounds like the issue is a clog somewhere in the fuel system.
When you drained the fuel prior to using the seafoam was it dirty? Also, after using the seafoam, was that dirty when you drained it? Is your fuel filter dirty?.
When trying to fix an issue, only perform one action at a time and reverse your action if it did not help before you move on to your next action. This will prevent you from compounding the problem.
As with the seafoam and fuel additive. You should only add one at a time and make sure the first is fully out of the system before you try the second.
Good luck!
Chucklesgolf (03-21-2016)
Old 03-17-2016 | 10:23 AM
bad tappets's Avatar
bad tappets
Could also be a pin hole leak in the fuel lines. Check for error codes as well.
Old 03-17-2016 | 12:48 PM
chromelens's Avatar
chromelens
I assume this is an EFI bike based off the year. In 2006 the FXD family had 8 degree injectors and these were known to cause problems. Check and see if the stock injectors are installed. If you eliminate all other fuel system/electrical possibilities I would look at this. Harley had a service bulletin about changing injectors from 8 degree to 25 degree that is all over the web/this forum.
Old 03-17-2016 | 01:03 PM
nevil's Avatar
nevil
All good advice so far. I would add that you should go over the settings in the Power Commander to make sure they are correct, sometimes they get corrupted. If that doesn't change anything, pull off the PC and see if that helps.
Also, those units can get water intrusion in the connectors, make sure it's dry and tight inside before you put it back in.
You're assuming it's a fuel problem, but loose/dirty battery and ground cable connections will make the bike act funny.
Old 03-21-2016 | 02:36 PM
Chucklesgolf
4th Gear
ok...due to my mechanical inclination (which is zero), I put the bike in the Harley Hospital. The seafoam additive was the only fuel additive I had put in.
I failed to drain the gas first, so not sure if the filter or gas was dirty. I guess I should leave the mechanical stuff to...wait for it.....MECHANICS!!! lol.
Thanks to every one who posted. May God bless and keep you, and keep the shiny side up and the rubber side down!
Chucklesgolf
4th Gear
Old 03-23-2016 | 03:43 PM
Chucklesgolf
4th Gear
Mechanic called today...said where the wires were run through the frame, where they exit the frame, they have frayed, causing a short. He said he has to remove the swingarm, and run new wiring. Cost....approximately $300.00. To those on here that do this kind of work, does that sound reasonable?
Old 03-24-2016 | 07:14 AM
sleazy rider's Avatar
sleazy rider
Damn reasonable. Swing arm removal is usually a 2-3 hour job alone. @$95/hour labor. Tire and all the associated hardware needs to come off first.
Chucklesgolf (03-24-2016)
Old 07-31-2023 | 01:37 PM
Fitness91's Avatar
Fitness91
Stage I
Default Help!
what did the mechanic tell you? I’m having the same issue with my bike currently.
kballowe
06-25-2012 11:25 AM
dinerbucket
04-13-2011 10:28 PM
KBFXDLI
09-15-2010 10:15 PM
milfly
Exhaust System Topics
07-12-2010 07:14 PM
kennyjohn
06-15-2010 06:14 PM
