ClutchWIZ & CVO Clutch Spring
Old 01-17-2016, 08:11 AM
rsage's Avatar
rsage
rsage is offline
Stage I
Default ClutchWIZ & CVO Clutch Spring
I purchased the ClutchWIZ for my 2013 FLHTK and I'm wondering if anyone has put one on a touring bike without changing the clutch spring (37871-98A stock)?
I had surgery on my left middle finger and Dayton is coming fast and the stiff clutch may cause a problem for me.
I won't have any good weather up here to get it out and try the ClutchWIZ with the stock spring out for slippage so I'm thinking of looking for a CVO spring (37807-03 364 lbs.) as suggested on the ClutchWIZ site.
Old 01-17-2016, 08:33 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,867 Likes on 2,429 Posts
Hi from the UK and welcome to HDF. I like the look of the Clutchwiz, but unfortunately they don't make them for my earlier bike. The basic info on their website says to use it with your stock spring, so I don't see where the suggestion of a CVO spring comes from?!
Old 01-17-2016, 08:40 AM
Uncle Larry's Avatar
Uncle Larry
Uncle Larry is offline
Received 49,926 Likes on 19,371 Posts
Per their Web Site
Do not order a ClutchWIZ™ for a TWO WHEEL Touring model without upgrading your clutch spring. If you do not and order one anyway then the ClutchWIZ™ will not work properly.
Old 01-17-2016, 08:46 AM
grbrown's Avatar
grbrown
grbrown is offline
Exclamation
Interesting! That's in contrast with another statement: "It's that easy. Simply remove your derby cover, remove the 6 - 10 mm bolts, install the ClutchWIZ™ and adjust your clutch." Buyer beware!
Old 01-17-2016, 08:47 AM
Uncle Larry
I was thinkin' the same thing
Old 01-17-2016, 12:54 PM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,313 Likes on 1,861 Posts
At the Top of the page (which is the Home Page) that you found that statement, they also make the following statement"
Will reduce your Harley® clutch lever pull by up to 40%
Harley Big Twin Cam® Engines from model year 1998 to present
Tri Glide® - Softail® - Dyna®
"Tri Glide - Softail - Dyna" ... NO mention of Touring
On the same page they state:
It is important that you read the Tech Talk link. Read all the info on this site before ordering.
Where Uncle Larry found:
Do not order a ClutchWIZ™ for a TWO WHEEL Touring model without upgrading your clutch spring....
Keyword being "Touring"
Old 01-17-2016, 01:23 PM
grbrown's Avatar
grbrown
grbrown is offline
Yes, it's a bit of a jumble, that website, which is a shame. Rearranged it could be a lot more user friendly! I've read good reports of the product itself which is why, some while ago, I looked to see if one will fit my '90 Evo.
Old 01-17-2016, 01:31 PM
nevil's Avatar
nevil
nevil is offline
Received 1,036 Likes on 774 Posts
Due to an finger injury I installed the Clutch Wiz on my Dyna. This was a couple of years ago and in talking to the Wiz people (that sounds weird) there was no mention about changing the spring. Then again, it was for a Dyna.
Old 01-17-2016, 01:41 PM
multihdrdr's Avatar
multihdrdr
Was it your middle finger also? there might be a pattern here
What's your opinion on the Clutch Jiz? ...Seriously
Old 01-17-2016, 01:50 PM
nevil's Avatar
nevil
nevil is offline
Yes, it was my signal/middle finger. I think it's called RMD- Repetitive Motion Disorder, or something like that. Actually it was some kind of arthritis.
The CW helped a lot. Then I put on an Oberson adjustable clutch lever because I needed it closer to the bars and between the two the pull is very light and short.
My finger got a lot better and now I'm back to using it like before. Yay.
But I'm still gonna keep the CW.
randyp (07-29-2016)
Quick Reply: ClutchWIZ & CVO Clutch Spring
