ClutchWIZ & CVO Clutch Spring
Old 08-08-2017, 10:07 PM
D2wing's Avatar
D2wing
D2wing is offline
I have an 2001 police parade duty Electraglide converted to be like a Classic. The police model has a little heavier spring. Due to injury and degeneration of my hands I installed a Burly EZ pull clutch doohickey this spring. The difference was pretty slight. I was considering selling my bike or getting a Recluze Clutch. Then I found out about the Clutch Wiz and installed it myself in a little more than a hour, most of which was finding my tools.
I did not change the spring but I adjusted the clutch. I rode for a couple hours today and I was very happy with it. The clutch was nearly half as stiff. There wasn't any slippage at all when I hammered it and it shifted fine. If it is a fairly stock bike I won't worry about the spring, but the Clutch Wiz is easy to install so you just change the spring later if needed.
Old 08-11-2017, 11:03 AM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 6,018 Likes on 4,065 Posts
The only thing the CW did was allow you to change spring pressure with out removing the primary cover. You could have also gone to a lighter spring.. I would question as to whether of not the Burly arm was installed right as it reduces lever pull by a little over 30%.. You should be able to feel that..
Old 08-11-2017, 03:56 PM
mskirwin's Avatar
mskirwin
mskirwin is offline
Received 1,527 Likes on 1,151 Posts
My friend has it on his '14 street glide and I have it on my '15 limited. I did put the heavy duty spring in mine. He ordered both his and mine. He did not install the spring on his.
He. Has a hand problem and I don't. I drive in heavy traffic he doesn't. It's about 1/2 the pull even with the heavy duty spring. His is even easier. We are having no issues with slipping and even though I do not have any hand issues it's much better in bumper to bumper traffic. I would recommend just installing the clutchwiz without the spring and I'm sure you'll be fine.
His was 15 minutes, mine was about 1/2 hr or so, because you have to take the primary cover off.
Good luck either way.
Old 08-11-2017, 06:32 PM
Max Headflow
Here is the difference in measured lever pressure and how the pressure plate pressure changes with the clutch wiz.. Clutch lever pulls were checked on an 07 FLHTC with 18 degree clutch ramps (stock) .
The 103 spring is about 340 lbs so the plate pressure will be about 255 lbs. If you don't get on that much it will likely hold. One thing to look at is the primary oil and if it's getting darker between changes. If not you are likely good.
HarleyGTP
03-12-2021 09:37 PM
SoCalShovel
03-15-2018 12:53 PM
pomeara
Milwaukee Eight (M8)
01-04-2017 06:26 PM
redeye93
Screamin Eagle CVO Models
05-11-2013 05:10 AM
mking7
08-12-2011 10:51 PM
Quick Reply: ClutchWIZ & CVO Clutch Spring
