S&s 106 big bore kit
Russ, check those two kits closely. They may be two different solutions, one of them for use with stock heads, probably with lower CR. There are many kits around, for big twins and also Sporties, designed to boost performance with stock heads, which can flow very well. Changing heads, or porting stock heads, adds an extra improvement in performance, often with additional CR. S&S will tailor a kit to meet your requirements, if you wish, including cams etc.
James Daniels
Engine Mechanical Topics
11-03-2017 06:09 AM
