General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
Local seller has a set for 600. Can.
All I know is they from a limited.
Other than being 17" front and 16" rear what else do I need to know to ensure they fit my 2010 ultra
Thanks
As said all I know is they are off a limited. I can find out the year but if there are other questions i need to ask I would rather ask them all at once. Nice wheels but dont want to buy them to find out they wont fit a 2010 Ultra. Like is ABS or non ABS a factor?
If your bike has ABS and the other wheels are ABS, they will bolt right on. Vice versa if both are non ABS. All it would require is a bearing replacement if one is different than the other. FYI, the ABS bearing is 3mm thicker than a non ABS bearing...
Reason: additional info
