Air cleaner
The RED K&N spray is to oil cotton filters. It is not a cleaner. I use the following K&N filter recharger kit. It comes with a cleaning spray (works very well) and filter oil (Be careful not to over oil the filter).
http://www.knfilters.com/search/prod...x?prod=99-5000
Filters are usually made of one of three different types of material e.g. Cotton, Sponge/Foam or Paper. If you do not have a cotton or sponge/foam filter then it is most likely not serviceable. If you have a paper filter then I would just replace the filter element instead of attempting to clean it.
Also, if your air filter is exposed to the elements like the air cleaner below, invest in a rain sock. It will extend the life of the filter.
http://jokermachine.com/products/har...aner-assy.html
One more thing, the filter in the picture above is a 4 inch K&N cotton filter. The cotton is shaped and protected by a wire/metal mesh screen. Is this what you mean by "Wired"?
Good Luck!
Good Luck!
