New throttle grips sticking
Not that this is much help to you but I put a set of Khrome Werks bars on my '14 limited last year and had the same problem with the stock grips, the throttle would not return back, I had to use a liquid graphite lube that i use on bicycle chains on the bar under the throttle to make it pop back. I think it's an issue with Khrome Werks product.
Any way try a little lube, worked for me.
Honestly those were the ones I wanted to go with but the Kury's were a better fit. With the Avons I would have had to put the clutch housing over the inlet for the wiring, just didn't seem like a good idea.
Avoid using lube - dry or otherwise....I've seen that stuff turn gummy and make the situation worse.
Twice I've had bar/grip combos that were a little too tight for the throttle to snap back and in each case I solved it with a combination of scotch brite, fine grained sandpaper, and elbow grease.
Remove the controls and twist the sandpaper around the handlebar like your revving the throttle until it turns freely.
Done.
Done.
Done.
Done.
RomeoTango
2014-2023 Touring Models
21
01-26-2022 05:02 PM
