Norco motorcycle lift
$628
1000 Lbs Capacity Motorcycle Lift Air/Hyd.
787D Motorcycle Lift - 1000 lbs Capacity Air/Hyd.
Designed for raising exposed frame motorcycles 30" high for easy cleaning, servicing and building.
FEATURES
Space saving design leaves room in your garage.
2 3/4" Low Lift Height fits under most low profile customs and choppers
Infinite height adjustment up to a maximum of 30"
Two locking height positions for storing the motorcycle on the lift
Four premium quality tie downs provide a quick and easy way to secure the bike to the lift arms.
Patent pending lift design includes a Air/Hyd operated bottle jack as an part of the lifting linkage
Safety release **** provides slow controlled lowering of the load
Rubber pads on lift arms prevent slippage while providing cushioning to protect custom surfaces
Composite wheels and "T" handle for maneuverability in a shop or garage environment.
