dyno tuning
When I bought my bike, the dealer did a stage 1 and I think it's called a flash load or something just to make things better than what the factory had. When I had my motor rebuilt last year, before it left the shop, they did a dyno to make sure everything was set up to how my Indy wanted it to be. He had it close but the dyno made it better.
The stock cams are also designed to comply with EPA regs and the more mods you do that alter your bike from stock, the greater the benefit of having a dyno tune, to optimise it.
Hope that helps a bit!
Your bike came from the factory with settings that are designed to meet EPA regulations. By having a stage 1 done, plus the dealer download, your bike still complies with those EPA regulations. A dyno tune can probably only be done by adding a suitable tuning device, but that will enable the settings of your engine to be optimised away from EPA. That may also require removal of the catalyst. The benefit of the dyno tune will be a cooler running engine that will probably give a little more power and torque, but also be nicer to ride.
Even ignition the advance curve may be compromised by the need to meet EPA, so a tuner is a good thing and an add-on tuner makes a lot of sense.
are you saying the dyno tune? or the programmer is worth it? im up in Canada so NJ is just a bit out of the way for me. lol
