Swingarm pivot bolt STRIPPED
Hey guys...new to the forum but needed advice so signed up.
My swingarm pivot bolt is stripped at the threqds in the frame and i cant get it out. any tips or tricks to do this without butchering the frame?
i plan to use the MID-USA HARLEY PANHEAD, SHOVELHEAD STRIPPED SWINGARM BOLT REPAIR KIT 58-86 once i get it out
Thanks for the reply! I've been tryin that method with no success.... using a 4lb sledge and grade 5 Bolton even go a little. The threads were so bad that its spinning in the frame easily, but not by hand- yet doesn't want to come out.... maybe seized to the centre of the bearings?? I greased the swingarm just last season but who knows what the last guy did or didn't do...
I don't know if you have ever replaced a garage door spring but (bear with me you'll see where I'm going with this)
You use a steel rod to tighten the spring, that rod was the perfect size roughly 18 " to knock out my swing arm pivot bolt on my 1995 Standard Dresser, it was frozen in there very good and would turn but I couldn't get it out.
When I did get it out there was rust in the middle of the swing arm pivot bolt and that was what was holding it up, hope this helps.
Go to my DIY page on my site
