General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
I am having a problem with my throttle. It is in the grip. When I release the throttle and it snaps back and stops, it goes a little further past the stop point and sticks. I took apart the switch housing (where the starter switch and run switch are) but could not see a problem. Any help??
I ended up turning the star shaped, spring loaded adjuster screw under the switch housing on the throttle. I didn't have to turn it much. It did the trick and didn't seem to alter the idle when I start the bike. Before that I did lude the cables, that didn't seem to have any effect.
