General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
I dont think one has anything to do with the other. Sounds like a weak battery, is it the original? Or... bad/loose connection to the starter. Battery leads tight?
Hook it up to a trickle charger for 24. Hours. Chances are you ran the battery down the click click click is an indication of low voltage/current to thecstarter.
I agree, changing the oil has nothing to do with whether your bike starts or not. I think it is just coincidence so I also vote for checking out your battery or maybe even the battery connections, maybe they are loose or corroded, it's an easy place to start.
Nice intro...another ++ for checking your battery connections (both ends). Then go to New Member Intro section and give us a proper greeting...we're only all gentlemen here and would like to hear more about you vs. being the "ask ? and dump" type...
What Iceman said...
Tired of spending time trying to come up with an answer to help someone, only to realize that the poster probably never even read the answer.
