The $1 Harley
Old 07-26-2014, 09:47 AM
danwoods's Avatar
danwoods
danwoods is offline
So, I have proof that it runs. Videos and such, but I can't for the life of me, get them to post. Any suggestions?
  #132
Old 07-26-2014, 09:57 AM
woodman's Avatar
woodman
woodman is offline
Originally Posted by danwoods
So, yesterday I spent an hour at te parts counter at the local HD shop (uke's hd in Kenosha). I went through a laundry list of small fiddly parts I needed. They said they had everything on my list when I called. By the time I left the shop, I was carrying ONE fork reflector. 1. It was supposed to be a pack of 2 but someone opened the pack. Looks like everything is special order. It didn't cost any more, but I could have done all that over the phone.
Wow that's a surprise that a dealer would have parts. HD shows shovelparts as extinct in my neck of the woods. I do have a local shop that specializes in shovels.
  #133
Old 07-26-2014, 10:08 AM
danwoods's Avatar
danwoods
danwoods is offline
I may need their number.
  #134
Old 07-26-2014, 10:20 AM
Ron750's Avatar
Ron750
Ron750 is offline
Received 16,547 Likes on 6,276 Posts
Join Photobucket.
https://www.hdforums.com/forum/forum-issues/868122-how-do-i-post-picture.html
  #135
Old 07-26-2014, 11:10 AM
BoonDock_Saint's Avatar
BoonDock_Saint
BoonDock_Saint is offline
I use dropbox.com you can store and share stuff from there. It can back up your phone pics too if you want it to.
  #136
Old 07-26-2014, 11:16 AM
danwoods's Avatar
danwoods
danwoods is offline
https://www.dropbox.com/s/d3w45wb7sn...2017.01.24.mov
It lives!!!
  #137
Old 07-26-2014, 11:18 AM
danwoods's Avatar
danwoods
danwoods is offline
https://www.dropbox.com/s/d6el7lutrc...2018.41.01.mov
Close up of the engine on startup.
  #138
Old 07-26-2014, 11:30 AM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 48,986 Likes on 17,897 Posts
Tech tip and please heed this one it's critical for that bike. The rear pipe broke because it wasn't mounted up and supported well enough , aside from breaking like that they tend to either strip out the bolt hole going into the heads or worse case actually chip off a part of the flange. Repaired more than I care to remember .
Whatever pipes you use please make sure the rear of them are well supported together and tied into the rubber mounting bushing. FXR's will spit one in heartbeat if they aren't done right.
  #139
Old 07-26-2014, 11:43 AM
danwoods's Avatar
danwoods
danwoods is offline
Tech tip and please heed this one it's critical for that bike. The rear pipe broke because it was mounted up and supported well enough , aside from breaking like that they tend to either strip out the bolt hole going into the heads or worse case actually chip off a part of the flange. Repaired more than I care to remember .
So, stay away from the shotgun drag pipes?
  #140
Old 07-26-2014, 11:48 AM
TwiZted Biker
Oh they will work just make sure the are mounted up solidify & straight. Shovelheads will give you fits with pipes if they aren't and FXR's being rubber mounted and bouncing around in the frames take a little more care getting them right.
Quick Reply: The $1 Harley
