security pagers
RE: security pagers
The Range Confirmation Light on my pager goes out after about 2 hours even with the pager right by the bike. But if the alarm is set off the pager works. This sucks because I can't tell if I am in range or not. The dealer does'nt really know anything about this. Any one else having this problem?
RE: security pagers
I haven't heard of that problem. Have you replaced the 9V battery in the Siren?
This is assuming that the pager & 12V bike batteries are good..
RE: security pagers
I have had mine a couple of months. No problems. Also, the little manual states that in order to conserve power, it quits sending the signal after 2 hours unless someone touches the bike.
RE: security pagers
Yes page 8 of the little manual says
"In order to protect the power supply the security system will only brodcast the RCS for one hour. The security system will remain armed, and will alert the pager reciever in the event of a trigger if within range."
I guess you need to read these little manuals cover to cover before asking stupid questions. But I still don't like the fact your not sure if you are within range unless you get an alarm. All good things must have there flaws I guess.
Thanks for the help.
RE: security pagers
ORIGINAL: mooreto
RE: security pagers
My pager system also takes aaa batteries. Do you have the info on how to set it up for your bike?
I don't have the instructions for it and it has lost the match up with my bike. Need info on setting it
back up.
back up.
RE: security pagers
ORIGINAL: mooreto
[IMG]local://upfiles/13603/F11E3135CB894BFFBF26A27644BFB233.jpg[/IMG]
