Stripped Torx bolt head removal help
Old 04-04-2014 | 05:16 PM
ralfie's Avatar
ralfie
Question Stripped Torx bolt head removal help
I was removing the Torx 3/8" X 16 factory button head bolts on my triple tree upper bracket that cinches down the fork tubes and replacing with chrome bolts and one of the bolt heads stripped. I have tried everything to remove the darn thing.
I tried drilling it out and using a ez out, but discovered the bolt is hardened and it just eats the drill bits. I tried to get a hold of the bolt head with vise grips but can't get a hold of the rounded button head. I tried heating and penetrating oil. I tried cussing, but that didn't help either.
It's still tight and I'm not worrying about my fork tubes slipping, but it looks like crap and I'm mad at myself for not using penetrating oil at first.
I'm wondering if I took it to a machine shop if they would have a trick to remove it. Anyone have any ideas?
Thanks, Ralph
Attached Thumbnails Stripped Torx bolt head removal help-apr-04-2014_0377.jpg   Stripped Torx bolt head removal help-apr-04-2014_0378.jpg
Old 04-04-2014 | 05:21 PM
oldwarrior's Avatar
oldwarrior
Use a Hammer and tap it with a punch, worked for me when I had the same thing, just be careful, I had to hit it pretty good to loosen it up, I used my heavy A$$ framing Hammer.
Old 04-04-2014 | 05:26 PM
ralfie's Avatar
ralfie
I tried that also. I just can't get a hold of it because of the rounded button head.
Old 04-04-2014 | 05:28 PM
24v's Avatar
24v
I would bet an allen socket into it and try to get it that way. If that doesn't work, try to cut a line across the head with a dremel and get it with a big flathead impact screwdriver.
Old 04-04-2014 | 05:31 PM
RANGER73's Avatar
RANGER73
Cut a slot in it, square and deep. And use an old school impact driver and hammer.
24v beat me to it
Old 04-04-2014 | 05:52 PM
little5150's Avatar
little5150
I would take a chisel and on one side of the bolt, smack the chisel with a hammer. Hard to explain so look at my picture. Make sure you are hitting it in the right direction.
Old 04-04-2014 | 06:02 PM
PaiN's Avatar
PaiN
I had the same problem with a floorboard torx head. EZ-outs did not work, I drilled the bolt per spec but the EZ-out threads wouldn't catch....In a last ditch effort, I drilled the bolt a little deeper, then hammered a T-hex key into the hole until felt it catch and solid up. At this point I torch heated the key as much as I dared and a little of the bolt tract, I clamped a vise-grip on the key..with a little pressure **crack** the bolt turned and I was able to turn fully out
Old 04-04-2014 | 06:03 PM
qtrracer's Avatar
qtrracer
Carbide tipped drill bit and bolt extractor.
Old 04-04-2014 | 06:08 PM
skratch's Avatar
skratch
not to kick a guy when he's down, but did you use the wrong size torx on it? i've broken torx bits before i stripped that bolt head.
Old 04-04-2014 | 06:21 PM
ralfie's Avatar
ralfie
No, I used the right size torx wrench. The idea of cutting a slot in it with a dremmel, then a hand impact wrench sounds like a pretty good idea with a flat blade. I have a dremmel, but need to find small diameter diamond cutting blades.
Quick Reply: Stripped Torx bolt head removal help
