Hey, can you park a touring model on one of these when lowered completely? I have some storage limitations so just doing some planning. That could be a hassle though. How much effort to stand on end for storage?
keep my. Ultra limited on mine when I am not riding it
You might want to upgrade the tie downs, using an Eye Bolt,and then make sure to put a big fat fender washer on the bottom side under the nut. Those u bolts are pretty cheesy as are the little washers underneath.
Mount them up at the end of table, so when you strap it down and tighten it up, it locks it into your wheel chock.
Also FYI, looks like you lifted it with the ramp still attached. You do that too many times, the little "lock in nubs" will break off due to the weight and angle of the ramp. Suhweet though, you will love it. Oh, also, once you put that big black pin in, lower the table into it, so as not to have your bottle jack holding the weight....
