Saddlebag Fell Off!! Will Harley Davidson Replace?
Old 03-09-2014 | 02:29 PM
MrSkiPgh's Avatar
MrSkiPgh
6th Gear
Exclamation Saddlebag Fell Off!! Will Harley Davidson Replace?
I have a 2014 Street Glide and During a ride the Right Saddlebag fell off. After further investigation I noticed that the "Receptacle Stud" that holds the Pin in place that secures the saddlebag to the frame failed. The Hard bag has some pretty good rash. It needs replaced or at the least new bodywork.
Will Harley Davidson proper say "To Bad So Sad" Or will they accept responsibility and replace the saddle bag and make this right?
FYI- I have the full extended warranty program...
Please give me some feedback.
Sparky
Old 03-09-2014 | 02:34 PM
davidwruth's Avatar
davidwruth
I would think they May question how the bag was reinstalled after it was removed
Old 03-09-2014 | 02:42 PM
Dozer40's Avatar
Dozer40
I think it will be up to you to disprove operator error. Good luck.
upflying's Avatar
upflying
If you removed the bag at some point, they will hang the blame on you. I never had one fail. They are called Dzus Fasteners, pretty reliable design, used in racing and aircraft.
Old 03-09-2014 | 02:43 PM
big-e976's Avatar
big-e976
Had that bolt back out on mine and other buddies new bikes,but caught it early enough.
Old 03-09-2014 | 02:47 PM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
They would be the ones to ask. But, if it's under warranty, I don't know why it wouldn't be replaced, if it was never taken off since you've had it...it that could be proven. That's just an uneducated opinion.
Old 03-09-2014 | 02:50 PM
Glockmeister's Avatar
Glockmeister
What do you mean by "failed?" Got Pics?
Old 03-09-2014 | 02:53 PM
big-e976's Avatar
big-e976
I may be wrong, but i'm pretty sure he's talking about the bracket the fastener locks in to.
Old 03-09-2014 | 03:53 PM
petom's Avatar
petom
If it's a part failure, yes. Operator error, which is more common, no.
Old 03-09-2014 | 04:14 PM
simpkinst's Avatar
simpkinst
Sparky
How exactly did it "fail"?
I will bet that someone did not attach it properly. Hard lesson to learn, but trying to blame the company for an obvious user error is also not the correct path.
