Permanent connection to trickle charge battery
Old 03-04-2014 | 04:03 PM
Clash City Rocker's Avatar
Clash City Rocker
Stage II
Default Permanent connection to trickle charge battery
Hi,I've just recently imported a 97 softail custom into the UK from California. Because of our glorious winters here, I was wondering if I can fit a permanent connection on the the battery to make it easier to keep charged. Not sure if battery should be disconnected to charge it , thanks
Old 03-04-2014 | 04:06 PM
OKMICK's Avatar
OKMICK
Why not consider putting a 'pig tail' connector to your battery and then plug in battery tender as needed.
Old 03-04-2014 | 04:07 PM
1004ron's Avatar
1004ron
Welcome to the forum.
A regular trickle charger will over charge and damage the battery, as will allowing it to run flat. These batteries will never fully recover from a deep discharge.
What you need is an electronically controlled battery tender.
They come with a set of quick connects.
http://www.poweredadventure.co.uk/de...y-chargers.asp
Amazon.com: Battery Tender 021-0123 Battery Tender Junior 12V Battery Charger: Automotive Amazon.com: Battery Tender 021-0123 Battery Tender Junior 12V Battery Charger: Automotive
Old 03-04-2014 | 04:42 PM
AndreiTheGiant's Avatar
AndreiTheGiant
Attach
this this
to the battery of your bike with the two-pin connection poking out somewhere accessible -ziptied to the swingarm should be a good spot- and keep the bike plugged into
this this
when not in use.
Note that the second product (the Battery Tender Junior) ships with the first product (the harness) included already.
Old 03-04-2014 | 05:40 PM
Clash City Rocker
Stage II
Thanks you guys , I'll look out for that in the uk
Old 03-04-2014 | 06:47 PM
HDmikie's Avatar
HDmikie
FYI, you don't need to bring the battery indoors during winter. Just keep plugged in during storage. It works here in Minnesota so it will work in the UK.
Old 03-04-2014 | 06:59 PM
bdtaylor1979's Avatar
bdtaylor1979
Originally Posted by AndreiTheGiant
Attach this to the battery of your bike with the two-pin connection poking out somewhere accessible -ziptied to the swingarm should be a good spot- and keep the bike plugged into this when not in use.
Old 03-04-2014 | 09:02 PM
hdgzr's Avatar
hdgzr
Yeah, what they said. My pigtail is installed so it comes out just behind the seat on the RH side, and the little retainer on the weather cap loops around the upper swing arm to keep it out of the rear wheel. Hardly noticeable...
FenderGuy53
08-18-2011 11:35 PM
jacktana
07-07-2008 11:12 PM
nutmagnet
07-07-2008 08:23 PM
snuffer
12-03-2007 11:26 AM
falsealarm
11-21-2007 04:22 AM
Quick Reply: Permanent connection to trickle charge battery
