Noise
Noise
Okay then, how about this one?
Got my 103 FB out of the shed to go visit my parents today. Last ride was wet, and as I always do when it's wet, waited an hour for things to cool down and then hosed all the grit and crap off before sticking it back in the shed with the de-humidifier running.
Off I went today after letting the engine warm through whilst I put my gloves on etc.
Every time I eased off the throttle in traffic there was a strange noise coming from the top end on the right hand side. The best way I can describe it is as a crisp or chip packet being screwed up, a kind of metallic crunching noise. It was definitely the engine as when I coasted with the clutch in the noise stopped. I don't know if it was there under power as the exhaust could have been drowning it out.
On the return journey I revved the engine under load hard up to 5000 rpm and the noise wasn't there the next time I eased off the throttle, although the idle speed was playing up again and wouldn't settle below 2000rpm, which it does from time to time.
So any ideas?
So any ideas?
I know you said the noise sounds like it's coming from the upper engine area but......
The front hose clamp affairs on my exhaust heat shield were loose and rattled at times.
Metal sound for sure.......almost a "buzzing" noise.
If you do not have heat shields.......disregard.
My son was trying to find it coz I was really pissed off, and was tapping and knocking the heat shields, maybe enough to stop it buzzing.
Will see next time I ride it. I'm really pissed with HD. Seems to be one thing after another. Not Happy.
Okay, either you've read my other recent posts, or you're trying to say something, which is it, hey hey??????
found it.
Stuffed a rag in the exhaust so I could hear the engine noises at tickover and there it was plain as day, the crunching noise which was the.....................
butterfly valve in the exhaust rattling around as it's closed. Which explains why I could only hear it on the overrun, as most of the time it's open and the cable is keeping it from rattling as it's tight.
Don't know why it's suddenly started, must be a bit loose, with wear and tear I spose.
But at least I know what it is, and that it's nothing serious. Thankfully. Almost sold it coz I thought it was gonna go BANG! ha ha ha
The pipes on the FB are linked and just behind the link pipe is a butterfly valve in the top pipe only which has a cable running to a servo which is tucked away towards the rear of the engine, by the swingarm pivot area. Anything less than 2000rpm or on a shut throttle and the valve closes to keep the noise down.
Most guys here pull the plug and wind the servo motor to open by hand and leave it like that, but I've left it connected as it does a good job of keeping the noise down around town with the V&H slip ons. I don't like to encourage attention from you know who.
