Heel-Toe shifter is loose ?
Old 12-04-2013, 01:11 AM
BK-DE1's Avatar
BK-DE1
BK-DE1 is offline
Default Heel-Toe shifter is loose ?
When riding my shifter rattles. So I usually just hold my foot gently against the heel shifter. It's not the legs that are loose, it's the whole thing (the axle that They're mounted to). I didn't see any bolt, so I did some searches, and I guess there is one, but some people are saying "just tighten up the bolt" ? and some are saying, "DON'T tighten, but REPLACE it. Something about it snapping off ??
Anybody have this problem & fix it ?
ANY help would be great
Sorry....2001 Road King 15,000 miles
Old 12-04-2013, 03:51 AM
Bone Doc's Avatar
Bone Doc
Bone Doc is offline
Received 10,913 Likes on 4,135 Posts
There should be a bolt that holds the shaft ("axle" which the shift "legs" attach to) to the lever which attaches to the shifter rod.
You said you didn't see the bolt. Is the problem that you are missing this bolt? If so, replace and tighten the bolt. If the bolt is there, see if it is loose. If so, re-tighten it. Only tighten it until the axle becomes secure and no longer rattles. Use blue Loc-Tite.
Now, if you snug down the bolt and the axle does not become secure then there are other issues at hand.
Old 12-04-2013, 04:46 AM
hogcowboy's Avatar
hogcowboy
hogcowboy is offline
You must have mighty good hearing. Or you have a very worn shaft and the only way around that would be a replacement shaft. But I guess the question is, is it the shaft or one or both levers? The levers you can simply re-tighten the allen bolts or as stated above replace them if they are missing.
Old 12-04-2013, 06:56 AM
hdfat2001's Avatar
hdfat2001
hdfat2001 is offline
Rarely does the shaft wear out. There are 2 bushings in the bore that the shaft passes through, and they do wear out. The bushings are pretty easy to replace and shouled take care of the slop.
Old 12-04-2013, 07:11 AM
Blue SOG's Avatar
Blue SOG
Blue SOG is offline
15,000 miles and the shifter is loose? Somebody is hard on the shifter! Tighten the pinch bolt. But make sure the shifter is all the way on the splined shaft. Put a drop of blue locktite on the bolt. No way the bushing should be worn with those few miles.
Old 12-04-2013, 08:13 AM
Firebike32's Avatar
Firebike32
Firebike32 is offline
Had the same problem on our '02 Ultra. You could physically move the shaft up and down. Never leaked and the dealer didn't seem to concerned about it.
Old 12-04-2013, 08:18 AM
NDBadlands4-2's Avatar
NDBadlands4-2
NDBadlands4-2 is offline
The tow shifters have bolts that clamp the arm to the shaft. See if yours is loose.
Old 12-04-2013, 08:26 AM
fatboy slim's Avatar
fatboy slim
fatboy slim is offline
Tightening the bolts will not take up play in the 'axel' as you call it. I would call it a pivot or spindle.
The shift levers when tightened onto the pivot hold it snug into the pivot sleeve with the bushings. If the complete assembly is slopping about then the bushings have a lot of free play, or possibly have cracked broken and fallen out, as they are only plastic.
I suggest taking the shift levers off, pulling the pivot out and checking the bushings are intact, then if all is complete, pack it all with grease and re-assemble. The grease will take up any free play, and stop the rattle.
Old 12-04-2013, 09:53 AM
jamesw's Avatar
jamesw
jamesw is online now
http://partsfinder.onlinemicrofiche....&b=20&Action=O
Part #21 is my guess based on the description
Old 12-04-2013, 09:58 AM
Twistnride's Avatar
Twistnride
Twistnride is offline
I smell crap.
Quick Reply: Heel-Toe shifter is loose ?
