air pressure
Old 11-29-2013 | 07:37 PM
Cory81's Avatar
Cory81
Default air pressure
My buddy is running 8 psi to his rear 240 tire. I'm running 20 and my tire rubs my rear fender can I run 8 as well that seems a lil loe
Old 11-29-2013 | 08:14 PM
Dusty Bones's Avatar
Dusty Bones
20 is a lil low, about 50% low. 8 is suicide, go for it.
Air psi isnt the problem. Fix the real problem and run the right psi.
Old 11-29-2013 | 08:29 PM
Mercyfulfate's Avatar
Mercyfulfate
signed.
do what the tire recommends.
Old 11-29-2013 | 08:31 PM
themensh's Avatar
themensh
20 psi sounds low.............8 psi is for mud trucks. I would say get bigger fenders.
Old 11-29-2013 | 08:51 PM
Harleycruiser's Avatar
Harleycruiser
Eight pounds the tire is going to run hot, wear out faster, feel squirrely and if you hit any serious pot holes bend a rim, ruin a tire. Plus it will look like it is low all the time and when you loose any pressure you are screwed big time and wont know it because you are so used to looking at it flat.
Old 11-29-2013 | 09:37 PM
Cory81's Avatar
Cory81
That's what I tell him he rides a rigid and says its not as stiff when u hit bumps
Old 11-29-2013 | 11:00 PM
SanJuanRon's Avatar
SanJuanRon
8? Are you joking? That's for ATVs and RZRs, not for Harley's. Not only will the ride by terrible, you are putting your life on the line. And, 20 is also a big problem! Fix the real problem and run the tire pressure at what the manufacturer recommends. SJ Ron
Old 11-29-2013 | 11:01 PM
bdtaylor1979's Avatar
bdtaylor1979
Old 11-29-2013 | 11:04 PM
_Gir_'s Avatar
_Gir_
What?!
Old 11-29-2013 | 11:24 PM
TwiZted Biker's Avatar
TwiZted Biker
Somebodies full of **** I ran rigids for years and you never go under 20PSI in a tire or you run a real chance of the tire separating off the rims . We did run them between 25 and 30 psi to help with the road jars and not chipping teeth but no lower .
Another thing less air pressure allows the tire to deform and they can rub in tight spots , air it up and watch the sidewalls pull in a bit as the crown raises .
Quick Reply: air pressure
