oil drain plug TC96 part#?
Old 03-11-2007 | 12:56 AM
KeithB's Avatar
KeithB
Big Kahuna HDF Member
Default oil drain plug TC96 part#?
Anyone know the part number for the oil plug o ring?
Thanks
Old 03-11-2007 | 08:56 AM
dawg's Avatar
dawg
Default RE: oil drain plug TC96 part#?
I'm not positive, but I don't think the plug has changed from previous years so it would be 11105 I think.
Old 03-11-2007 | 02:02 PM
Tinkermc's Avatar
Tinkermc
my brand new shiney manual tells all about the oil change and the part numbers for the filter-chrome or black, the H~D oil filter wrench part number the torque setting for the plug and to be sure to inspect the o-ring but no part number given.Sorry
Old 03-11-2007 | 03:37 PM
KeithB's Avatar
KeithB
ORIGINAL: Tinkermc
I resd thjst in mine too, not listed in shop manual either.
But i bet someone here has the parts manual
I have both 11103 and 11105 they look identical [8D] Just wonder which is the correct one?
i know know tranny uses the same, but does the primary drain use a diff o ring?
Old 03-11-2007 | 04:01 PM
ROADTRAIN's Avatar
ROADTRAIN
Ibuy mine at the hardware shop in a packet of 20.
Nothing special about a 0 ring.
Make sure you get the correct size.
Old 03-11-2007 | 04:24 PM
High Gear's Avatar
High Gear
What he said
Old 03-11-2007 | 05:11 PM
KeithB's Avatar
KeithB
ORIGINAL: ROADTRAIN
cool but i guess you would wanna be sure they are for oil
Old 03-11-2007 | 08:24 PM
Dave_E's Avatar
Dave_E
My H-D parts counter guy or gal would answer that question over the phone and their in stock. Yours won't? C'mon Keith.
Old 03-11-2007 | 08:32 PM
High Gear's Avatar
High Gear
Good Point Should be oil resistant .
Buna-N: In the Buna-N family, you will find compounds which are ideally suited for oil resistant applications of all types.
( taken from an O-Ring Manufacturer site )
Here's a company that I do business with at work . You can order direct . click here
I'm always forgeting the O-ring when I'm picking up a filter
Looks like a pkg is $3.00 or so (100 ), cheaper than driving 10 miles to my nearest dealer .
Old 03-12-2007 | 12:53 AM
UncleMike's Avatar
UncleMike
The o-ring for the oil and tranny plug is #11105 and for the primary #11324.
Quick Reply: oil drain plug TC96 part#?
