How can I find out of I have a 96 or a 103
Old 10-08-2013, 08:58 PM
tenn volunteer's Avatar
tenn volunteer
tenn volunteer is offline
Veteran: Marine Corp
The jugs look bigger?? Larger pistons in the 103, the bore is larger. The exterior of the cylinders are the same.
Old 10-08-2013, 09:07 PM
shredder22's Avatar
shredder22
shredder22 is offline
Me likey big juggs......hehehe
Old 10-08-2013, 09:24 PM
MikeBel's Avatar
MikeBel
MikeBel is offline
Received 1,564 Likes on 671 Posts
Are those big jugs natural from the factory, or is there a big layer of silicone on them? I always prefer OEM equipment myself.
Old 10-08-2013, 09:27 PM
bdtaylor1979's Avatar
bdtaylor1979
bdtaylor1979 is offline
Originally Posted by cmcoyner
Ok ok I guess I should of put more info in I bought the bike as a 08 street glide with a 96 but it is runs stronger than my buddies 08 street glide with a 96 and my jugs look bigger wanted to know if the numbers on the motor would tell me anything with out me pulling the motor apart
Maybe your 96 motor has more/better performance upgrades???
Old 10-08-2013, 11:02 PM
RHPAW's Avatar
RHPAW
RHPAW is offline
Received 15,163 Likes on 6,705 Posts
Rev it up to 5700 RPM, put it in gear, and dump the clutch. Measure the black mark. It will either be 96" or 103" long.
Old 10-08-2013, 11:30 PM
TwinCooled's Avatar
TwinCooled
TwinCooled is offline
It just keeps getting better and better. "my jugs look bigger"
We are really gonna need to see those big jugs!
Old 10-09-2013, 01:36 AM
6 gun's Avatar
6 gun
6 gun is offline
Received 1,747 Likes on 982 Posts
The only way to tell is pull one of the heads and measure
the bore with a micrometer
Old 10-09-2013, 07:03 AM
V-Man's Avatar
V-Man
V-Man is offline
Old 10-09-2013, 07:46 AM
Def Mute's Avatar
Def Mute
Def Mute is offline
The serial number will only tell you what it came from the factory with...
The only other way to tell what it actually is now, is to open it and measure the cylinder diameter and multiply that by the stroke. Anything less is just a guess, unless you can find the previous owner(s) and they can remember what they have done or had done to the engine.
If it has a fuel management system, like power commander, the map description may indicate if it was designed for a particular engine displacement. But, that is still no guarantee because someone may just like the way it runs on that engine, even though it was designed for another?
Head work might not always be part of the build. It could have been done in stages, with the displacement being first in line, and head work put off till the budget would allow going forward...
Cams installed? Still no true indicator of displacement...
I forgot to mention...
Those guys who are laughing at you, well they are just trying to get a mental lift from all the laughing at they received before they joined a good forum and learned some of the things which experience will never have a chance to teach them...
Old 10-09-2013, 08:03 AM
tinmarine's Avatar
tinmarine
tinmarine is offline
Have you asked your buddy what has been done to his bike? He might just have a download vs. race tuner, stock cams? Do you know any upgrades that you have? If yours has a 103" the seller private or dealer would usually mention that upgrade as it's a bit of a selling point.
Quick Reply: How can I find out of I have a 96 or a 103
