We joke about voiding the warranty. WELL....
#61
My local dealer sells Amsoil as part of the service so I will go under,, if they sell it HD must support if it does not work!!!! Been using Amsoil in my truck for 15 years and no problems at all.
#62
How does that justify that it am soil causes engine failure? Just because some one was to stupid to fill the engine to capacity. 1/2 quart in a 6 qt pan. Gas it's exxons fault if it ran outta gas..........
#63
My dads 09 ultra is currently at the dealer getting the engine rebuilt under warranty because the bearing where the connecting rod connects to the crankshaft went bad. He has been using amsoil. They didn't void his warranty but they did tell him that amsoil is what caused the bearing failure and that they recommended not using any synthetic especially amsoil. They said that they have seen too many mechanical failures from using amsoil. They could just be blowing smoke, I don't know.
#64
One thing is for certain. He lost 50% of the cost of a new engine because somebody didn't teach him right. You fill the tank full when you get fuel and check the oil every time you do it. As important as oil is, that's a no compromise rule for me. And on a motorcycle? I won't start one (at the beginning of the day) without checking the oil; on a long ride, every time I get fuel.
#65
i'd like to see what the new indians say about oil, etc. in their warranty section of the owner's manual. i would wager to bet that it says something similar.
#66
Anytime a place makes a claim such as that, just ask them to put it in writing, on the businesses paperwork, and sign their name (legibly) underneath it. Same with the shop claiming amsoil voided 50% of the warranty in a vehicle with one oil change in 18000 miles. If they are so sure that it was the oil, and not crappy owner maintenance, then put it in writing, otherwise it is bullocks.
#67
They are blowing smoke. "Recommended not using any synthetic"? THEY use synthetic in their newer models (pure syn or blend, I dont know...haven't purchased oil from them ever in my 20 years of riding HD's). I'd be curious to see if they would put that in writing on dealership letterhead....I'm guessing they won't. I'm not in the amsoil camp (just personal preference...not dinging them in the least), but if Amsoil were evil, dealerships wouldn't be selling it. If synthetics were evil, harley wouldnt be putting it in their CVO's, or selling it (at a premium) in their parts-room.
I don't care if amsoil says you can go 10k-20k miles on an oil change. I never have and never will be comfortable with going that long on a single oil change. I use synthetic in my truck and bike and change each every 5k miles.
#68
My service manual for the 09 says if no HD brand oil available to use a diesel spec CG, CH or CI grade oil.
That tells me that HD oil is most likely specified as one of the above. I have been running a dual spec SL/CI-4 Grade diesel oil in the Softail and the BargeGlide for years without issue. Lifters on the Glide are as quiet as a church mouse...
#69
Overkill and Paranoid are a couple of words that come to mind. How many times, and how much oil, have you needed to add on a daily basis? Once you have a little history on a vehicles oil consumption rate I see no reason at all to check the level as often as you. If you all of a sudden puked a quart or two between fill-up's I think you'd know that without having to check the oil level.
If someone wears a helmet but has never fallen and knows they've never taken a tumble; does that constitute overkill as well?
#70
Thats a little different. Powerstrokes (at least the 6.0 I had) pressurizes the oil to some 4000 psi.........thats what shears the oil.
