Stock Harley carb or Mikuni & which intake manifold?
Since I am gathering parts for the EFI to CARB conversion, I thought I would throw this out there. There were some older threads, however, I'm looking for some fresh insight.
Seems like the two are close in performance, how are they to work on? Easy dis-assembly and access to jets?
Intake manifolds - S&S? I looked at their kits, are those Super-E carbs good?
40? 42? 45?
40? 42? 45?
I had a Harley CV Carb, then a Super E Carb on my 1996 RK (EVO).. Honestly, I wish I had went to the Mikuni. The CV had the best mileage.. the Super E had better performance, but MUCH worse mileage and I could never dial it in the way I wanted. I've heard Mikuni's are the way to go and after my experience with the CV and Super E, I'd choose Mikuni now but I can say I haven't used one before.
As with so many things in life you have plenty of choices. I for one have always run S&S carbs because of their ease of tuning even while still on the bike.
Have a new HSR45 Mik with manifold on a shelf was going to use on RK problem was throttle cable interference under tank and had to remove carb to make any changes.
40? 42? 45?
40? 42? 45?
Every part in the S&S carb is available through a wide distribution network or directly and the documentation and tech support are first rate. Tuning is easy and well documented. Fuel mileage is excellent when properly tuned.
I've used Mikuni's on other bikes (Norton Commando). They are great carbs that can be finely adjusted...but they aren't as well understood as the other two. There is a great tuning manual available thru Sudco (large Mikuni distributor). I used the older round slide carbs, but I'm sure the HSR (flat slide) is equally good.
They will all work, but if I had to spend money on a new carb it wouldn't be a CV. If you already have one it's worth a shot as cost would be minimal.
S&S might be the most complete solution for a Harley as it comes with everything from intake manifold to air cleaner. And who doesn't like the iconic S&S air cleaner??
I had a HSR42 on my 2000 Heritage. Noticeable difference in power and performance between the Mikuni and the Harley carb. You won't be sorry if you put a Mikuni on your bike. No fitment issues either.
