Wrapping pipes?
Wrapping pipes?
I once heard wrapping your pipes affects performance. Is there any truth to this or is it complete bull****? I was considering wrapping my black thunderheaders. Anything else to consider? Thanks in advance
RE: Wrapping pipes?
Every little bit matters when you are talking about competition. The wrap keeps the heat in and keeps the exhaust gasses expanded so the velocities are high. As far as I understand, that's the benefit. But those exhaust systems scavenge a lot more than a typical street exhaust. Without the scavenging, not sure the extra exhaust speed would help.
I think the performance increase on a street bike is negligible. I've heard of heat related weld failures so take that into consideration as well.
Kevin
Kevin
RE: Wrapping pipes?
Header wrapping is mainly done to prevent other things from getting hot from heat radiation, such as under hood temps in race cars. As far as performance, I've never seen any actual before and after results so it is probably unmeasureable.
RE: Wrapping pipes?
I don't care in the racing sense. I could care less as far as numbers go. I just mean as far as something I would notice in the feel of the bike or it being something that would not be good for the engine. Thanks again for the help.
RE: Wrapping pipes?
Actually it does help performance,but you will not feel it in the seat of your pants.In my case,because of close proximity of pipes to body parts,the first foot or so of pipe will be wrapped.As far as drag racing,pull up beside me and we will see what happens.Tsk Tsk
RE: Wrapping pipes?
For those of you who have, any special technique to share. It'll be my first time doing it.
RE: Wrapping pipes?
ORIGINAL: rawhead
Also...don't expect the heat to be reduced all that much...your pipes will still get hot enuf to melt the heel of a boot (or the heel of an Air Jordan 19se).
RE: Wrapping pipes?
That's definately not good roadtrain. I haven't heard of that happening before. Jumpman did you use thermo-tec wrap. Any particular brand better than another. Does anyone know by any chance if thunderheader does repainting on their black ceramic. I've got some oxidization on the exhaust right by the mid mounts. Not a huge deal but just curious for the future.
