Do you check oil level hot or cold?
Old 08-30-2013 | 10:24 AM
Ron750's Avatar
Ron750
Default Do you check oil level hot or cold?
I just changed my oil to Mobil V twin 20-50. Engine was warm, and it drained fully. I added 3 quarts, ran it for a minute, it went up to 32. I shut down and checked level, and added 1/2 quart.
Today after riding 20 minutes I checked level, but the whole dipstick seems to have oil on it after wiping off and reinserting. Do you have to let the oil settle a few minutes?
When I checked it an hour later it is right where it should be for a cold engine, and easy to read. Why can't I check it cold? Seems a lot easier.
Old 08-30-2013 | 10:37 AM
Big_Al47's Avatar
Big_Al47
I normally check it cold
Old 08-30-2013 | 10:38 AM
LoveHate's Avatar
LoveHate
Hot, 5-10 minutes after stopping the engine.
Old 08-30-2013 | 10:46 AM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
I've done it both ways. But I usually check it before I ride, so it's usually cold.
Old 08-30-2013 | 10:50 AM
soft 02's Avatar
soft 02
Both. No difference.
Pete6114's Avatar
Pete6114
Thats how i check too
Old 08-30-2013 | 11:15 AM
DanRC's Avatar
DanRC
I have checked both ways and makes no difference. I usually do it before a ride so it is cold.
Old 08-30-2013 | 11:17 AM
ringofld's Avatar
ringofld
I don't' like burning my hand on the exhaust.
Cold don't burn me.
Old 08-30-2013 | 11:25 AM
Woofron's Avatar
Woofron
My service manual specifies hot, with the bike on the jiffy stand.
Old 08-30-2013 | 11:34 AM
ynots's Avatar
ynots
After a ride I let it idle for 1-2 min (per manual) before shutting it down then check it. On a cold check I wouldn't add any oil unless its below the mid range point on the stick. 96B motors with the external oil tank may be different?
What do you mean by "it went up to 32"
Quick Reply: Do you check oil level hot or cold?
