2006 Street Glide fuel gauge always reads full
I've done a little research and it seems like the problem may be the float being stuck. Is this a pretty simple problem that I can fix from home?
Run the fuel low, then take the console assy off. The float assy is a little tricky to remove, but just jiggle it and it will come out. Once out you will see on the end by the float a little tip that sticks out, just snip that off, and you will be good to go.
rns99
06-12-2012 04:07 PM
