Anyone know how big you can build a 88 motor?
Old 07-11-2013 | 11:24 PM
flyguy9631's Avatar
flyguy9631
Default Anyone know how big you can build a 88 motor?
Are you better buying a 96 or 103? Or even bigger?
Old 07-11-2013 | 11:29 PM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
you can go 97 without stroking it
the engine that is, do what ya want on your own time!
Old 07-12-2013 | 12:38 AM
slickrick_58's Avatar
slickrick_58
There are some 98" kits out there. HarleyCharley said 97". They are marketed as 98" but actually not quite there, 97 and change.
Stroke the motor to 4.375 inches (96C.I. crank) and you can go to 107" approximately.
If you are stroking it you can also bore the case halves for larger cylinders and go to 124".
There is always the, off the shelf, 120R engine option or any number of other aftermarket engines.
All it takes is cash!!!!
Old 07-12-2013 | 12:22 PM
Oldskewl's Avatar
Oldskewl
I stroked my shovel to 108"
You can do anything you want within reason depending on your cash flow
Old 07-12-2013 | 02:16 PM
FNGonaRK's Avatar
FNGonaRK
Most builders will tell you that a hot 95" will do damn near anything and smoke a stock 96" or 103". There is no replacement for displacement and all that. Anything you can do to a 95" you can do to a larger motor, but $ for $ a solid 95" with some head work, cams and a tune will keep you smiling from what I've seen.
Old 07-12-2013 | 03:02 PM
Bill03E's Avatar
Bill03E
I know a guy that is building a NASTY 95" motor right now, he is a tech at a dealer, I can't wait to see how it does on the dyno. He had 108hp, and 117tq with 211cams , and stock heads.
Old 07-12-2013 | 03:11 PM
Eagle_1's Avatar
Eagle_1
Plus 1.
Old 07-12-2013 | 09:20 PM
gamble71's Avatar
gamble71
the 95 will do everything you need, and more, unless you're looking to build a drag racer. However, for those who "enough is never enough" you can build a 107 with the factory 4" stroke. A 4.125x4.00 makes 107. I know I'm gonna do it one day... never seen an oversquare Harley... wanna see how it works. I was raised on 60s hotrods where big bore and short stroke were the hot ticket.
EL in NH
Engine Mechanical Topics
41
12-09-2022 10:54 AM
John Secosky
05-28-2018 08:49 PM
HTRAUD
01-18-2012 11:38 AM
jackinthebox
05-27-2011 11:25 PM
PDDGM
01-26-2011 04:54 PM
