Horns
I saw one at a dealership, with a sign...DO NOT TOUCH. I asked the guy what the deal was and he hollered "HORN!" He told us to get back and blew it. It was f-ing loud. I don't know who made it but it'd scare the hell out of anyone who wasn't expecting it.
Received 2,530 Likes
I bought two Fiaam replacement horns off Amazon, about $12 each. I got a low note and a high note. Tapped them into the stock horn wires (left it on also, three horns now) and mounted the two new horns on the two gas tank mount bolts aimed forward. Not really noticable unless you were really looking for them.
"Much mo bettah!" A loud harmony indeed.
Some folks go with 6 volt horns, some of them scream bloody murder.
Hey, to each their own. Do a search, lots of ideas in the forum...
I have heard some air horns get pricey and don't hold up. I'm OK with my set up, got to do better than the stock horn, for sure. Stock sounds a little like a clown horn, doesn't it?
I used to have an old classic hot rod Chevelle that I replaced the two factory horns with four old Cadillac Fleetwood horns I got from a junk yard. Sometimes I would stomp down on the throttle and blast those horns just to watch construction workers jump into the ditch!
Wolo Bad Boy from harbor frieght. Need to install a relay its an easy install and I have mine installed where the factory horn was and I know some separate the comressor to make it an easier install.
I've installed MiniBeasts on my last two bikes -- much louder than stock, simple plug-n-play install.
I probley should not be riding because the one time in my life that that a horn could have helped, the horn was next to the last thing on my mind. The last thing on my mind was my Butt. LOL
1 Post
It's a good idea to blast your horn every time you take your bike out. When I took my bike for its first mot test at 3 years old it hardly worked because I had not used it in the 3 years, if I had needed it I would have been fooked.
